my next question would be, if we can't use larger injectors untill we have better control of the ecu ( thanks product tester), what about using the factory injectors with a FMU and have a larger rate of gain than 1:1 ?
fella, you started comparing a freaking car engine to this sled simple cycle engine.....two completely different applications...this alone will turn folks away
think of an injector as an application specific variable orifice, it has a min and max range to work with for its fuel demands and air demands, an orifice is sized to work with X amount of pressure and X amount of flow.....you can only open the orifice so much more before it flat out don’t work with the application.
