maybe someone can answer this for me. why can't we just put 2 larger injectors in and use a rising rate of gain regulator that you can adjust the gain on (1:1-7:1). I would think if you put 2 larger injectors in lowered your base fuel pressure down to make them flow the same as stock off boost, then set your gain at above the 1:1 ratio on boost, till you find the sweet spot you could get away from using a 4 injector setup. in fact you wouldn't have to run a control box all together although it would aid in tuning. oh and of course you need a larger fuel pump aswell.
Maybe I'm way off here and someone can fill me in.
