On a few occations over the last two seasons on my turbo sled, I "loosened" plugs, I actually would make the center ceramic loose, not the base, all of which happened after the sled backed down... or hit the rev limiter, not sure which as I didn't have the vipec at the time, I went up two grams of weight and it happened once after, I attributed it to detonation, as the det light would flash. Light Flash's when it hits the rev limiter as well from my understanding. The last time I damaged a plug, it cracked a ring land, messed up the lower case, hench my engine is at Indy Dans. Happened on a uphill climb, got some air, kept it squat... she made it running, minus a hole in the motor and a number of turbo fins....
I'll be adding 7 tooth drivers and a 3" 156 track for this season, by the sounds of this I'll be speaking with Gino on some gearing options.
