I will be changing to 8t 2.52 drivers to put a 2" lug track on my XLT this fall. I need the smaller diameter for clearance. May have to change a little on the clutching/gearing side of things but not sure yet.
Here is a good thread that I have saved with good info in it
http://www.snowest.com/forum/showthread.php?t=85500
Hope this helps!
Probably been debated before, but please report if you yourself has tried this and how it worked! Might have to because of rpm vs. top sprocket...
Well.. Thanks for sharing, apreciate it. But they were talking about 8 tooth 3" pitch drivers, not 2,52" pitch.
But thanks anyway.
i have a chart that shows ratios for 8t 2.52, in 9t equivelents. what ratio do you think you need to achieve?, i can cross reference it for you.
How big of bottom gear can you fit?
