VIPEC and Cody Phillips
If you go on YouTube. Check out some of Cody Phillips vids. Silber with Vipec. Don't watch the vids with launch control. They will scare the crap out of you!
One night late I was digging through some vids. I finally ran into a Pro vid that really sounded crisp. Most sound like brrrrrrrrrrrrrap. Finally something that made me consider upgrading from my carb turbine.
I would give you a link, but I just got off the short bus.
I am considering having Bryce or Cody build me something next year. I don't just want a 'kit'. When you are a back yard builder for years, you have something particular in mind. I too think that about the Precision situation. I think Bryce and Cody outweigh that though. Plus with stand alone the possibilities are limitless. I have not talked to them on the phone but I have some ideas.
Also, maybe pawpaw will chime in. I want to see what his results have been.
Hey Guys, I have not been on here in a while, been out riding!!! I wrote a long drawn out story about my experience and hit the wrong button and it was gone, so now I will give you the short version cause I am not a good typer and don't want to do it again. Those with more questions can message me. Okay, I have a 13' Pro with a 13 Silber. I rode it all of 12/13 season. I wasn't unhappy, it had it's bog here and there, probably mostly my inability to push the right buttons, but it worked, and really good for the most part, but I wanted more. My Silber dealer at the the time talked me into Fastracks port and polishing, and a PAR head with turbo domes. Which both are awesome companies and I've use their stuff before so that was not a big deal. After doing this, first week of April, we could not tune this sled in. My dealer said no biggy he would write another map, but season was over for me so we wait till fall. In fall of 12' I had talked with Cody Phillips about a VIPEC. But my Silber dealer at the time told me if I went with a VIPEC I was on my own and he would not help me. So I did not do. So... back to fall 13', my Silber dealer tells me that I need to just put on the Bullydog and all is good. I had talked with Justin before this and Justin told me the BD would not work for my mods, I would need to go back to stock, or stay with the Dobek box. Easy decision, I called Cody, talked over the pros and cons with him, (were no cons), loaded up my sled and headed for Cody's place in Utah. We installed the VIPEC, sensors, etc, in about a day and a half. Cody had wrote a map from scratch based on my description of what was done to my sled. We test ran on the stand and it was almost perfect, I would say 90%. So we headed for the hills. In about 30 min on the mountain Cody had it dialed the rest of the way, I headed home the next day. A few days later I rode up in the Stewarts, and did some Data logs to show Cody. Another cool thing Cody did for me, a switch on the dash to turn logger on, and a 2 position switch to change fuel maps, one a little leaner than the other. We sometimes unload at 1800' and run up to 6000' before we ride. So I had a rich map for down lower so I could play, while the rest of the guys baby theirs till elevation. Cody remote logged in a couple times to fine tune and we were done. This sled flat rips, only problem is Cody's sled ripped harder. I got to ride his sled in Utah at 17lbs boost. That ruined me, haha. After a couple weeks at home I couldn't take it, I had Cody order me a Garret GTX 2867r, with Tial housing and Tial MVS gate, same as him. Makes sense to run the same thing your tuner is doesn't it? So no I am not running a Silber any more, I have nothing against the Silber. I have a heavily modded sled, almost 35K into the build, I say this not to impress anyone. I built this sled over 2 years, and it's something I have always wanted to do. And I wanted the best, in my opinion Cody, VIPEC, Garret, and Tial are the best right now. But the key here is Cody and the VIPEC. He is amazing at tuning, and the VIPEC will do so much that you can't believe it. There is no one better at tuning than Cody in my opinion, my sled flat runs. I don't worry about bogs anymore, or hesitation, or if it's gonna work, cause it just does, plain and simple. Cody is more than just a tuner, he got me all the parts I needed and provided installation advice along the way. I haven't been with out a problem or two, but it has not been with the turbo or fueling. I had some issues designing my oil tank, and how/if it should be vented or not. I stretched the factory head studs right out of the gate and blew a head o-ring. Then lost reeds(I had about 800 miles on them so it was time). Also lost bearing on jackshaft and wobbled out my C3 pulley and stripped my drive belt. But no fueling issues. Cody is awesome to work with and knows his stuff. I don't want to take away from the kit builders. They got their work cut out for them, they are trying to make a kit that works for everyone, at every altitude, in all snow conditions, with all sorts of different fuel qualities, etc. I would not want that job, they are trying to make every ones dreams come true. Their kits probably work on 80% of the sleds.. 70% of the time.. in 60% of the conditions. Cody only has to make YOUR dreams come true.. on YOUR sled. His map is specifically designed for YOUR sled, not one for a hundred, it is custom tailored and tuned for YOU!!! That is the difference. If your gonna buy a mass produced kit, your gonna have to deal with some tuning issues, all there is to it. If your using a kit with a VIPEC, if its not perfect then something is wrong, probably the tuner?? For all those on the fence give Cody a call, I wish I would have a year earlier. I have about the same $$ into mine that I would buying a high end kit, difference is this is mine, I have some things done you will not find anywhere else, I have 1/4 second or less of turbo lag and the logs to prove it. If things go as good as they are, I might sell the piece that is making this possible, along with Cody's knowledge of tuning. I don't know a dang thing about tuning with the VIPEC, I don't need to, Cody is a phone call away. A BIG thanks to Cody Phillips, you have made my sled everything I knew a 2-stroke turbo could be. -Aaron. PS, I in no way want to discount what Justin Silber is doing, he is making leaps and bounds in the turbo market, especially for a small independant guy(not corporate boondocker type). I didn't want to hi-jack this thread, but wanted to share my experience with Cody and the VIPEC...call him, you won"t regret it.
One thing I wanted to add, I did run the VIPEC on the Silber kit and it was awesome. It ran better with the VIPEC before it was fine tuned than the best day it did with the Dobek box, it's not even fair to compare them. But to answer anyone questioning this, the answer is yes, It runs awesome with the VIPEC, if I had to choose between upgrading my 13' Silber kit to the BullyDog or getting the VIPEC, it's no contest, I'd do the VIPEC!!! Its almost same price as BD upgrade, but way more options, especially if you have future plans for something different.
