Interesting answers. I think comparing and stating your results from the past (pre solenoid activation) is why many are trying this on the present engine.
But is this comparing apples to apples? Was not the soleniod thrown in there to control this opening time so the 'putor thinks it knows the valve is open and adjusts accordingly?
Gonna be a long post here but I have wanted to play with this for a while. 'Cause I ain't stock lol and I had very favourable results in the past adjusting this on some modified engines in the past. Usually to the side of earlier opening from stock set-up.
Haven't been able to find answers in the last couple of years either lol.
DTR has shown CFM is higher with the valve closed. Late opening creates lean det condition (big CFI4 issue) because of the simple FI system with no Mass Air Sensor compensation. Play around in this spot may lead to lean-det condition eventually collapsing the skirts or worse from the piston crown overheating.
Poo has installed these springs for a while. They have the softer ones in stock too. If the solenoid dictates opening they could install the soft ones and still pass EPA stuff because of this feature. It's non-adjustable unless you have a Vipec or access to Poo over-write software.
One thing is for sure, the 'putor only knows when the solenoid opens. There is no electrical connection to the actual valve.
Why are the stiff ones in there? Are the softer ones an actual or part of a "fix Kit"?
So, theoretically lol, what peops are saying is the valve does not open when the solenoid does and putting in softer spring will make it open sooner. Hmmm.
My testing in the old days with Doos (pop out indicators on the valves in the spring without hood on twin pipe 670's) has shown me this function is only open or closed and no in between of any length of time. You could install any spring with any preload and change opening time but never create a multi step like the modern mechanical valves. You could go too early and get to too late but this was a simple system without the solenoid.
I'd like to know how people gathered this info and posted it because I've been trying to figure out how to watch the actual valve function (too old and blind to hang over the bars and watch nowadays lol).
To change something you need to first know what it is doing. I'd like to try an earlier valve opening on my Pro and I think I can do that mechanically adapting some aftermarket Doo RAVE stuff I still have kicking around. Thing is I don't want to do it just seat of pants way if I have an alternative.
Has someone figured out how to observe this in field? Or, are we still quessing? I can't afford a Vipec lol.
Some have said softer springs make the valves open earlier. How do you know that? My seat of pants feel I expected (more growl-shudder-pull in mid-range that I have experienced in the past when power is increased lol) didn't happen.
What does that mean,, nothin' lol.
My Pro showed some issues with rpm drop when stock (read it here many times too). Work the throttle in the deep and sooner or later the r's would drop. First thing I thought of was valves closing but not returning to open (cause it's happened before) because my clutches were cool.
Then I observed a temp correlation too.
So, I did TRS's Thermo mod and his recommendation of lighter springs all at once and have not had this issue since. I "believe" the valves stay open now and the temp has made a difference also. Was it more of one or the other??
But,, the one thing I didn't get rid of is a particular det spot (anyone in tune with their Pro will know what I mean) while running more compression. I actually needed to run 2 maps to get to play from top to bottom. Can't afford race fuel either lol.
My past experiences from similar case scenarios has showed me that opening the valves earlier has eliminated this "det spot" and allowed the continued use of a bit too much compression with the side benefit of more mid range when "carbed" correctly.
You can slow up the rpm increase but why create an RPM issue at another shift point?
Last year I chewed up the holes in the barrels and lowered compression while tightening squish and it was good and gone but I want more lol.
TRS. You have very specific recommendations and I've found them to be spot on. Can you shed some info on your findings and why you came to these conclusions?
Others that have posted or not any more info?
