That's not correct.
There may be tunnel width issues, but the 2009 and 2010 gear sets are not the same. The 6203 bearing and spacer is wider on the 2009 and previous models than it is on the 2010 models. The stock bearing and spacer on the 2010s are ~15.9 mm and the 5203 is ~17.5 mm. You will be putting a side load on the bearings on both end of the gear set if you put the 5203 bearing in the 2010 case.
There are a few threads on this already. There is a 4203 bearing that is 16 mm wide. I would suggest you go that route instead of the 5203 for 2010s. For some reason, the 4203 are tricky to find in the US. If anyone is interested, I will have a few extra of these that I will sell at my cost. If anyone has a source in the US, please let us know.
Hey newtrout, any idea when those 4203's will be in? Let me know as I would like the 2 asap.
