Who Has Hit DET???
Who has crept up in boost till they found detonation? Did the knock sensor catch it before catastrophic effects? Also, has anyone had spark plugs back out before hitting the DET sensor? Probably most interested in IQ/Dragon sleds. Thanks in advance!
Good info-thanks! So you have had spark plugs back out before piston failure?
I had some messed up fuel lines in the tank causing a lean condition below 1/2 tank tripping the DET sensor. I did lose an electrode off an Irridium plug then...they are in the garbage now. Going to run the Doo plugs this year.
I'm getting ready to see if these MTNK pistons can take 16-18 lbs with 106mon and two degrees of retard. I was at 13lbs with 100ll and stock timing.
I'll watch plugs and pistons. Any more thoughts are appreciated.
