Which weights
06m7
Hi guys I just finished ordering my pipe and can combo for my 2013 m1100t just wondering which adjustable weight I should get I'm leaning towards mds but what do u all think thanx
I'm on my third set nothing but good things so say about Steve's stuff.
MDS...... Steve has been spot on in helping us develop a clutching setup for our Evo products. Steve will setup our weights to our specs before he sends them out so its a plug and play. Great product!
Installed Steves weights today @ 85 gr and about fell over when I saw the yellow/white spring compaired to Steves suggested polaris black-
It is a full 1 -1/2 coils shorter than the stock yellolw/white
Is this correct?
S/C
If you just did pipe and can what do you need weights for? Stock should be on the mark.
He may be wrong- the MDS will set u up @85/86 grams should be spot on
The pipe is not going to make it rev higher..
S/C
can
When I put a can on my 1100 hit the rev limiter all the time. It needed more weight.
Hitting rev limiter is what I call over reving ill try the pipe and can before I put the weights on
Been hitting rev limiter ever since I put the poo black spring and mds weights in. Talked to racinstation and he is sending me out another spring from speedwerx. Haven't got it yet but hoping this is the trick cause the weights definitely make a difference. Anybody looking at the dalton secondary spring for the 1100T? Both my bushings are shot in secondary never blew a belt or even pulled a cord but wondering if secondary spring is binding.
How many miles on the sled? I plan on ordering MDS as soon as mine comes off of the Dyno so i will have all of the information to get exactly where i want to be.
Giving Dakota performance weights a try this year. If I dont like them ill go with MDS.
