Which to use?
Fuel Controller Options
Depending on where you live or ride you may not need one but the PCV has fixed some running issues with many sleds and increased reliability and helped to cure the lean burn down conditions from Polaris's maps. The PCV program from dyno jim adds fuel in the midrange rpm and then leans it out at the top end which has got 10-12 additional hp then the stock sleds tested on the dyno. The BD control box seems more limited control wise on my Turbo D7 but also works differently. The PCV is my choice for a stock D8 and it works very well IMO and is well worth the $400 from Dyno Jim.
2005-06 fuel management?
Is there a fuel management component that works with the 2005-06 900's? Is the others for newer years able to wire in to the 2 injector set-ups?
Eric, I believe there are a few controllers for the 900. Dobek, and the boondocker box come to mind.
Otherwise I would go with the PC V for sure. The features and control it gives you are endless. And it is still fairly new, so there should be even more support coming in the future for it.
