I'm haveing the same problem! Like the flexibility of the Shockwave in Roosterbuilts kit, but it is also one more thing to have to adjust. and i've heard DJ's 08 and 09 kits are spot on. Give us some help, who's used them????
Most of my clutch kits can get dialed in right off the get-go.
A certain percentage need the flyweight changed up or down after a day or two of riding.
Some of my kits require a different primary spring, one with a higher or lower final force.
The 07 rev & 08 xp model if using stock 415/413 ramps you would change the clicker from road to snow to maximize mileage on the road and correct rpms in the snow.
I made ramps for the 07/08 model to compensate for this so one would not have to change clickers. In addition, my ramps make quicker rpms off the bottom end than the 413, a tighter connection between the throttle and snow.
The 09~10 model you don't have to change clicker between road and snow.
For the curious about a clutch kit and for the owners of a clutch kit old or new and
regardless of which vendor you buy a clutch kit from, here is
a reality check;
There are some sleds that are exceptions to where the kit had difficulty to work and what causes this? I have had owners install the wrong primary spring, lose the secondary swivel washers, put their levers in backwards,
Cotter pins installed with tangs bent in wrong direction(
catches on the spring cup and can break a tang upon 1st time clutch engages), cotter pins installed backwards(c
Bad primary spring cover bushing(can happen while stock), tapered sliding sheave button galley(can happen while stock), secondary rollers scraping the sheave casing(can happen while stock), cracked secondary rollers(can happen while stock), seized secondary rollers(can happen while stock),
wrong ramps(dealer changes from 413 to 412 or 417 without informing owner), wrong levers -
I haven't scratched the surface because I can go on a tirade mentioning engine management problems (raves/kinked hoses / fouled solenoids / low compression / wrong spark plugs(weak power) / low battery voltage = low rpms / rubbed through wires(can happen while stock) unadjusted throttle (from factory)
I'll say one little basturd of a problem is the voltage reg wire that gets rubbed through on a tunnel rivet. Had owners get new ecu's and could not get the clutch kit to work and even back to stock and still the power of a 440 at elevations.
...anyway, the clutch kits normally work great, however if the customer has a problem, I try my best to help figure it out and come up with a remedy.
