Which Can? BMP, HPS, Skinz, MBRP?
Something not really talked about much. If under hood heat is an issue you are concerned about, a smaller can with less surface area will dissipate less heat inside the hood. So not just the coating but also the surface area will affect the amount of heat given of by the can inside the hood.
Not another pro can thread.
Hps seems to be the most preferred. It's what my buddies put on their pro's.
Can
Check the search tab type "Best can for Pro"... theres enough threads you'll be reading all day.
HPS or BMP for loud sound
SLP for a little quieter.
I think you'll find the HPS is probably one of the more popular ones. Hence, I got one.
DO A SEARCH!!!!
The point of these forums is to keep up with the changing technology. Why even start any new threads then.....cause according to your post everything about everything snowmobile related has already been said. So I guess we tell everyone to stop posting cause its already been said or covered.
My vote is skinz. I've always used them and if you can't find one try sledsolutions. My.02
