Where's everyone mounting their bullydog gauge
moto_786
Where abouts on the pro are people mounting the tuner? Has anyone found a good waterproof case for them yet or are they standing up to the snow and wet fine on their own?
I have mine in a small pelican case (1020 model i think) i found the first ride with it that it is not water resistant like bullydog claims. I dont always have it on u less im checking pressure or intake temps to try and figure out the damn bog.. Works well where i have mine mounted. Just drilled a 3/4" hole in it to run the hdmi cable through.
I'm not sure what they look like yet...ordered and paid for them in early November and still don't have them!
they are waterproof. the buttons are compacitive touch buttons which means if water gets on them they will start changing gauges. but as far as the board and connectors they are water proof. although some have somehow gotten water in them.
I know they are claiming to be waterproof, but on the second ride i had water behind the screen and decided to keep it in the case so when i remove it once my boost is set it is in a protective case.
I think they removed the plastic sheet that was over the screen and applied a screen protector on the screen so you don't get the moisture stuck behind the screen which makes it look bad.
