Where do you guys mount the p2p button on a dragon. Seems like no matter where you put it it would be difficult to use. Pics would be helpful
DON"T PUT 10. When you are on the button you will be at 18. Plus hp is how much added boost to your set bst number. So, put in 2 in the plus hp. and you will be at 8 off the button and 10 on the button. Your EBC will still show your set bst setting regardless of whats in your plus hp. So if you have set 8 and 4 for plus hp on the button then it will still show 8 but you will be getting 12 when full boost.For p2p, the ebc says plus hp, if I run 8lb, and want the p2p to run 10 should I put a 10 or a 2 in the plus hp screen?
