Where do I find the accessory plug
Is there an accessory plug on the 600,wanted to plug in an outlet for heated visor.some one had mentioned before when discussing heated grips,just plug them in.
I found a couple plugs with caps on the end,the single one in the pic is yellow/power.If this is where it goes can you buy these matching connectors.
My heated shield came with a harness with large bullet connectors
what is this wiring harness from.It must be out of a brp sled.It seems from all the post I read on this topic in the sled sections that brp makes adapter plugs and splitter plugs for most
Cap is the plug,
remove rubber plugs, and install male Ski-Doo terminals after crimping your acc., these were supplied in all tool kits when new.
Yes I see that now and had I read the manuel a little better I would have seen that ,although I did not see anything about the terminal in the kit ,I do remember seeing one in there.
I also found out that the other blind plug is for an optional tach.Is that optional from factory or optional aftermarket
thanks
