Wheel/dolly kits
Tuesday
Post up your pics here of the things you have used to move your TS or yeti around the garage. I know both companies make wheel kits for moving and off road riding but I am curious what the diy have come up with for basic day to day use. I put the dolly that I used on my sled it worked but took 2 people to get it stay balanced. Need a work around.
http://www.timbersled.com/en-ca/shop/accessories/transport-wheel-set/pid-16-sb-002
http://www.timbersled.com/en-ca/shop/accessories/all-terrain-wheel-set/pid-16-sb-001
https://yetisnowmx.ca/wheel-kit/
Have you looked at my ad for a snowbike dolly in the classifieds? I make the slickest mover you can spin the bike in a 360 degree or tip forward and work on track off the ground or tip back and remove ski if you want!I do have it so it can be shipped! Uses 13 inch wheels so will roll on gravel. email is hotshotlm@gmail.com or call me 208-880-6068 I can send better pictures. Larry
I run a complete yeti front end on my CMX kit. It works pretty dang slick grabbing the rear bumper and able to steer it around the shop. Also, nice to be able to ride it up the trail on sub par snow days.
The CMX's track freewheels so easy you can push it around without rear wheels under the track.
Your Yeti wheel kit won't hold the track off the groung to spin track or work on it ,but the cart will! Plus in a tight garage the cart is way more manuverable , each one has its advantage!
run the Yeti wheels and they work great. With the yeti wheels i ride up on sled decks. dont get better then that.
