Whats a GREAT SOUNDING blow off valve for a 23 Turbo?
This is purely for FORM over function. :ROFLMAO:
I am looking for a blow off valve that has a really clear clean sound to it that would be easy to pick up on video.
I need it to be unmistakable when heard.
Any suggestions?
RPM powersports blow off and boost tube works good.
1 / 3
RPM Ski-Doo / Lynx 850 Turbo Blow Off Valve ( BOV ) Kit
$99.95
RPM Ski-Doo 850 Turbo BOV Kit
RPM is not new to the BOV industry by any means. We have created this BOV and its spring rate specifically for the factory 850 Turbo Ski-Doo based on its vacuum drawn at idle and while NOT under boost. Our kit uses a Patent Pending boost refence port that install post TB's and before the reed valves. The RPM BOV kit not only improves throttle response but takes the stress of the turbo flutter off the turbine wheel allowing for quicker spool times. This kit does require the use of the RPM Ski-Doo 850 Charge Tube for BOV installation. This installation can be done on the machine safely by an experienced mechanic. Basic mechanical abilities allow this to be installed with the throttle bodies off as well. Detailed instructions are provided
Fits all Ski-Doo & Lynx Turbo models, Gen 4 & 5
  • Quicker Spool Time
  • Turbo Longevity
  • Lifetime Warranty
  • Detailed instructions
  • BOV filter with Pre-Filter
  • Stainless Boost Reference Port
