What would you do?
What would you do if you were in this situation. A local shop opened up that had a great bike tech and a certified sled tech. The tech came highly recommended from a large shop in Colorado, and has shown in the past in working on your sleds that he knows his stuff well. You personally had used the shop for bikes and sled work.
You then refer the mechanic roughly 10k in work over the following months. Including tune up work and a complete motor overhaul. The guys you have referred to him are basically helpless when it comes to motors so they are at the mechanics mercy. You go to take your ride and half the freshly set up and tuned sleds are fouling plugs and or not even starting. So you being the one guy in the know resets some carbs and does some cleaning and chalks it up to bad gas.
Then your buddies sled with a brand new motor melts down within the first 5 or so miles. You take the sled to the mechanics first shop, the shop that recommended him and they say well the head bolts are loose then back pedal and say it could be anything. Then 5 days later you get a call from the mechanic that rebuilt the sled and he states its rider error and you should have known it was overheating. Mind you the temperature sensor never kicked on as an overheat and when looked at by me was broken in the head. Upon your initial inspection you can see that the coolant is extremely low but was not blown all over the engine compartment and was also not pungently burning through the exhaust.
To go with this you know that he once before sent a sled out with a new motor that was “heat cycled” 4 or 5 times but then burps and the coolant drops a considerable amount within the first 10 minutes you ride it.
Would you pay for a second opinion on the :cause: of the burn down? Would you put another motor in at your expense? Would you look into options for getting this taken care of legally? What would you do in these shoes? Right now I feel like an ******* that recommended what I thought was a great shop and have seen problems with 8 sleds from there out of this group of 13…
I am not going to name names yet, however the current shop is not one of the big ones. Its juist sad as I had great luck with this shop, but this is really a major problem.
if the shop wasn't willing to work with me on these issues... I would name the shop!:D
wtf do you expect us over the internet to trouble shoot your troubles?
He's just asking for advice about dealing with the situation diplomaticly.
I would approach the shop who actually did the work, tech first. If he's unwilling to correct the issue talk to his boss. If the boss is unwilling to correct the issue go to the better business bureau.
You're right for not naming the shop until you give them adequate time to resolve the issue, but I take it if there are 14 people involved in this, their anonymity won't last long anyway.
I know that's a crap position to be in, but someone else's work really isn't your fault. Live and learn...
No prob man. Hopefully everything works out. It sounds like they are definately at fault on that one sled at least, and something needs to be done to rectify the situation. Props to you for not throwing them under the bus publicly before they had a chance to fix it.
