What would you DO AGAIN?
Lets here some of the best upgrades you have done. What made the biggest difference from stock
I just put a set of F.U. boards on my M from Mountain Fit Hoods. Cheeper than the other ones and they look great.
best mod on a 08 and older is the PowerClaw, after 09 cheapest best is a pipe set
best all around, turbo
Ole's riser
IsoVibe SX
Powderhounds with 9" Shaper bars
'09+ HCR steering link
Dalton adjustable weights
AC gold primary spring
What do you mean by the HCR steering link?
Got tired of straightening the bent thin-walled stock aluminum tube multiple times on both my M8s. The tie-rod tube for '09 HCR and '10 Ms, is larger in diameter and machined from solid bar stock.
0605-994 - Tube, Tie Rod @ $23.77 ea
Item 33
Item 33
I have a HCR and this is true!!! Works way better lot stronger
07 M8 ...
SLP pipe
PC track
Boss seat
Head/Port
3" riser
SLP skis
Eliminate stk intake
VE bumper
RKT helix kit
CPC boards
RSI grip heaters
Venting
Goggle bag
CPC adjustable weights
401K loan
BDX oil inject elimination this yr .. we'll see.
