what to do on limited budget??
M
mezz250x
Looking to add some power this year, but im unemployed so i cant do everything i want to. Was thinking either SLP exhaust, head/shim kit, or porting. What do you guys think? Which on is the most bang for the buck?
How much is your budget? I would say rkt head and dial in your clutching. Spend the rest of your money ridding since your not working.
my budget is one of those options, they are all about the same cost. I do have a shift assist in it, and different weights and helix are on the way
I would do the rkt drop in kit. You get his head and the shims. Good luck with everything.
i would say the first things you buy should make the sled handle better and more comfortable to ride.
handle bar riser
Fastlane No-Sno's
Powder Pro skis
Spend the money on a good interview suit. You can mod the sled later.
lmao....you make a good point! To bad my job is kinda specialty work and theres nothing out there right now. Good thing for the unemployment checks!
I would go with the slp kit, then next you can go to the full performance package. Also works very well with dakota performance porting. and is putting out hp # a few above a 2010 m8.
09' M8 153; I would spend my money on gas and oil. I borrowed my friends stock 09' M8 SP last season for a day and sat the XF1000; was the best day I had all season, gas and oil man, gas and oil....
