Just curious how it works? Retard timing? Does it cause a decrease in power/performance?
How much HP loss roughly? Has to be some.
So ran setting on ethanol even though I always run non ethanol 90 octane. More dino no corn please
Sent from my SM-T217S using Tapatalk
Unfortunatally this is off original topic, but why do you guys think you can get away with running the non-ethanol mode with ethanol fuel at higher elevations? Yes there is less air up higher thus less fuel is needed to operate at the correct air to fuel ratio. But your computer is already compensating for the elevation...so that your air to fuel ratio is always proper.
Running Ethanol fuel in the non-ethanol mode at any elevation be it 15,000' or 1,000' is creating the same lean condition. Thats why they come with any ethanol mode for ethanol fuel.
ps, I would think if the fuel injection system worked perfectly as it should there should be no switch necessary, it should be able to figure out what to do with the fuel its given, all of our cars do..
