What is your setup
pictures
my new suspension pics
I want to get a thread started for hawk setup what is your elevation.
2007 800-144
8-10k elev.
modified air box
compensator
primary clutch 160-290 spring 415 ramps 13.5grams pin weight
secondary straight 44 helix with black spring
digitron tach
acerbis handguards
2005 600HO
144 ZX2 with 2.25in ski-doo finger track extroverte drivers 151 ZX2 suspension weight 55lbs 3lbs lighter than 136 expert x
tra II quick clickers 228 ramps green/white spring
Cat Roller secondary green spring 53/47 helix
Koso EGT
12 gal fuel tank
Vapor gauge assy
Hotdogger
steering post moved forward 2 inches
440 lbs weight without fuel
sweet~|!!
now thats a sweet hawk!!!
I have a 2005 600ho 136 with a Simmons ski ,attac, p85 primary clutch with a almond/blue spring and 56 gram weights, i also run the 530 chain drive instead of the "tls" I now have three seasons on it and have not had a problem. Stock driven clutch but going to install a arctic cat roller on this season.Also moved my bars forward two inches and up 4 inches
2006 600HO 136
Stock clutching as for now
installing attac kit
Custom HHgrafix.com
Snow tracker kit reversed. Out side.
Need to find out what that extra fuel tank Les installed on the Hawk. Very well done. I already hacked off the rear fender to install a fuel rack. But I think If Les can give me the skinny on where that tank came from. >>???
last year when i checked the 12 gallon tanks were $750 us. Thats why I cut out my tail light and made a bracket for a spare gas can.
tks suspension!
is that suspension for a 121 off the 600 that everyone says is too stiff? i need it,how much shipped to 14075 ny? i just bought a track from someone else but i might take it all if the price is right....eric
suspension
2007 800-144
8-10k elev.
modified air box
compensator
removed front coil spring on skid
digitron tach
acerbis handguards
2005 600HO
151 ZX2 with 2in challenger paddle Ported & extroverte drivers
TRA II green/white spring 13.9 gram weights 228 ramps quick clickers
cat roller secondary 53/47 helix green spring
atacc kit
12 gal fuel tank
simmons Gen II ski with pivot
Acerbis handguards
Vapor gauge Assy.
Hotdogger
Ready to ride weight minus fuel 440lbs
What is that blue suspension? What about the frame side? Thanks Bud.
Here is my current setup, but it is going to change a lot by the start of the season:
04 600HO
8-10K
pod filters
tiny tach commercial
cycra handguards
hand warmers
simmons gen II ski
stock 121 extended to 136
arctic cat roller secondary with straight 45 helix and red spring
custom gas rack
So I made my changes and have taken it out a few times, here is the synopsis:
Originally started out as:
04 600HO
8-10K
pod filters
cycra handguards
hand warmers
stock ski
stock 121
stock clutches
Then was:
04 600HO
8-10K
pod filters
cycra handguards
hand warmers
simmons gen II ski
121 extended to 136
stock primary
custom gas rack
Now is:
went to 800HO motor
remapped MPEM
jaws exhaust with stinger restrictor removed (thanks to TLKDPROD's suggestion)
8-10K
pod filters
twin EGT guages
cycra handguards
hand warmers
simmons gen II ski
ZX2 suspension
151 track
anti-ratchet drivers
P-85 primary
4140 steel jackshaft
custom gas rack
2007 800-144
8-10k elev.
modified air box
compensator
digitron tach
acerbis handguards
2005 600HO
atacc kit
12 gal fuel tank
Acerbis handguards
Vapor gauge Assy.
Hotdogger
how did u atatch flap to zx2?
