I wasn't meaning to point a finger at you, as I understand you were just quoting the magazine.
Adding oil to fuel actually leans the mixture which would make a lean midrange even worse.
The oil pump rod is located on the inside of the throttle bodies and routes to the oil pump under the throttle bodies. I haven't looked yet, but I would imagine that you pop the rod off the throttle bodies, remove bodies out of the way and pop the rod off the oil pump. Then shorten the threaded rod 1 full turn.
There is an adjustment screw on the throttle body end with a jam nut to hold it in place. Loosen the jam nut while holding the adjustment screw with an allen wrench, Turn it clockwise to raise the oil pump lever arm ( increases oil consumption). You match up some marks that are down on the pump that are real hard to see,need a mirror or for info My setting took 3 complete turns clockwise to be correct. I adjusted from the muffler side of the sled,more room than on the clutch side
