What Happened to the Push for Push Turbo's
I`m running 10lbs of boost on swedish pumpgas with stock head, stock "modded" fuelpump, no problems and no deto. I`m going up to 12 lbs soon.
Running at 1500 to 5000 feet.
Added a water intercooler and a external fuel pressure regulator, modified ignition. besides that a Push PG kit with 2871 upgrade.
I just got mine installed last weekend. Running 8.5 lb of boost stock engine 2.5gal of 112 added and no issues thing flat rips.
Do you know why Ken changed the oilpump and cooler from last year? What kind of pump is the new one?
Why doesn't everyone run AV gas? Alot better than mixing, better quality fuel and so dirt cheap compare to race gas in every way. Race gas is expensive around here too, from $600-850/ 55US gal(205L) barrel and I can stuff 221L of 100LL AV gas in the same barrel for $353 with tax(5%) out the door for my next trip. Looks, smells and works just as good as race gas & I'm up to 10lbs of boost going to 12 from 2500-7000ft riding. Try 5lbs at 1000ft and work up from there too...
Should be abled to get at an airport, the biggest hassle is making it worthwhile for them to sell it to you and your friends. Make it worthwhile to them and it shouldn't be a problem. Have them fill up barrels at a time instead of jerry cans and you should have them sold in no time. I can get mine filled locally here straight from the Vnose of my enclosed trailer, better than going to a regular gas station! :face-icon-small-hap
x2 i like to as well, or is race and av the same
