What gearing?
i was thinkin about a lager bottom gear but the dealer was sayin it like $100 or more for new bottom gear and new chain. If i got a top gear i wouldn't have to get a new chain but does it do the same as a lager bottom gear?
Cutlers says that you should use the largest upper gear possible. Your clutch will be more efficent.
So if you can get the same gear ratio from using a 20 on top and a 43 on bottom, or if you used a 18 on top and a 46 on bottom, then you should use the ratio with the 20 on top. hope that makes sense.
