First off... no one here is being an A-Hole.. Just a good discussion.
( though I've been one at different points in my life.. LOL.)
frisco... have a look at the inside fwd roof of your tunnel...You will probably find rub marks from the track if you are running 8 tooth drivers and the stock or 2.5" track like most sleds I've looked at with this mod running a loose track (even bone stock sleds have this because of the small clearance)
Here is my take on the whole tension thing from some other posts (cut/paste)
Mountainhorse: Loose track = poor track performance...especially on stiff duro tall lug tracks like the Ch ext. if the track is looser than stock... stabbing is more likely, the track will lean over and cause other problems... Correctly tensioned tracks perform better... don't take my word for it.... Call Bruce Dashnaw at Camoplast or Jack Struthers at Carls cycles. Also, a loose track will further choke off the tunnel opening as the track "balloons" out at speed.
Running loose tracks was necessary on the early M series as that was the only way to get the skid to work... Polaris does not suffer from this problem.
I know many California riders that have over 1500 miles on their original hyfax... and that is running stock everything, less bogies add scratchers. Our snow is pretty darn hard and lubrication is less than ideal.
The rolling resistance between an 8 tooth and 7 tooth is not that big.... there is a big difference between pulling on a track on the stand to judge drag.... and the driver actually driving the track with the weight of the sled/rider on the track. This applies to running big rear idlers, which on the RMK's, if you go larger than 8" you will see more drag and slack track problems.
The boundary layer of water on the coolers keeps the tunnel pretty darn clean, even at slow speeds. The UHMW PE would further add to the snow evacuation... I'll stand firm on my opinion that the snow flows through the tunnel on the Raw like water down a river.
Personal experience with the 2.5" ch extreme with 7 tooth drivers.... it works well, especially if you have the track at the correct tension.
even with the Avid Combo drivers... Keep the track tension stock on the track... a loose track allows the track to distort, the paddles to fold over a bit more than normal and gives poor performance.
I believe that loose tracks that distort under load are the major reason for "stabbing" NOT the fact that the rails are trimmed or the teeth are "sucking" the track up between the the driver and rail... a tight track cant get "sucked up" in that gap. Early M-Cats had crappy rear suspension geometry that HAD to run the track loose... those are the ones that gave rise to the phenomena of stabbing...loose tracks to follow suit... stock Doos don't have stabbing problems, they have short rail tips and no issues with stabbing on a wholesale level.
The new single ply tracks will stretch more quickly than previous models and need to be checked for proper tension quite often (tension instructions in your Owners manual)
Proper tension = better performance than a loose (out of spec) track.
Mountainhorse:Looser tracks allow the paddles to fold over easier... a part of the equation that most dont think of and is the MAIN reason why (I think) Jack Struthers says that a tight track works better than a loose one...it hooks up better, expecially in more setup conditions like on a track or hill-drags, or spring time climbing (or our average Sierra cement)
The people with Extrovert (AKA combo) drivers seem to want to run the track real loose and feel it frees up HP...a loose track allows for distortion of the track as it leaves the driver and makes the track more suceptable to "stabbing"... With the extros, I dont look at them as a way to allow a track to be run looser... I look at it as a prevention of ratcheting in the high-demand situations.
I think the "combo" drivers are the best option, but run almost as tight as the stock drivers AND run the more slippery hyperfax as well as popping back on some idlers for spring conditions as well.
Extros, IMO, are mandatory on high hp sleds... BUT they should be run at the correct, not loose, tension... similar to normal tracks/stock-drivers.
When they are running normally, not ratcheting, the teeth of the extro are not even contacting the track or the clips and only drive from the involute portion on the inside of the track.
The first of the M-series cats had poor geometry that tightended up the track when it worked thru the travel and caused all kinds of problems that was the big factory push to extros and the one that gave the extros and stabbing a bad rap
Do NOT run the track too loose.... many people do with extros and end up stabbing the rails thru the windows... IMO, too loose of tracks by people with Extrovert drivers is the main cause of stabbing track windows with the rails ("stabbing")... most sleds do not, IMO, need anti stabbing kits...
There is a difference between an extrovert and a combo driver... unless it is ratcheting, the teeth on a combo driver never touch the track.
Mountainhorse:Loose tracks may "pull" easier with the sled off the ground... but that is not the case with the sled in motion, with the weight of the sled on the track and drivers turning the track... rippling as it is pushed down the hyfax.
You can't compare the power required to turn track being pulled by hand on a stand and one that is in use, under power with traction... these are two completely different scenarios.
Also, with the Combos on ANY Polaris RMK>....Run STOCK tension specs if you want the track to perform well...especially on the lightweight single ply tracks....The myth that a loose track will turn easier and use less hp is just that... a myth... Loose tracks are more prone to stabbing, the paddles lay down easier, the track balloons out and rubs on the tunnel or decreases clearance, and there is more friction along the hyfax when the sled is in motion with the wieght of the rider and sled on it....Turning it on a stand with the track off the ground is NOT representative of what is happening with a sled on the snow and in motion.
