What 3" lug track to run??
Z
Zone28M7
So I've got an IQR that was converted into a mtn sled. Holz tunnel extension to 155" and I put a Pro RMK skid under it. I've got 3" pitch and need a 15" wide track. But I'm looking for 3" lugs. I can't seem to find a track that's 15 wide, 155 long, 3 inch pitch and 3 inch lugs. Any ideas??
Sent from my iPad using Tapatalk HD
Really the only short 3" thats made is the 156x2.86x3" I believe.
You'd have to cut it to 15" or have tracksUSA cut it and run 2.86 drivers, you'd have to run 7 tooth for clearance and most likely remove your front cooler and or drop and roll....too much work on an IQR probably unless you're really itching for that 3".
Already got drop and roll. But yeah I'm starting to think that I may be SOL unless I wanna switch drivers.
All the three inch tracks are 3 inch pitch. And if you wanted a 156 you'd need to cut it down to 15 wide, they only come in 16 wide. The 162 comes in a 15 wide and is lighter than the 156 because of a different manufacturing process. If I was you I'd get a set of 162 rails and run the 162 x3
