Kelly
Not sure if this is your issue, but I've seen weird electrical problems caused by wiring harnes rub-through at the left front motor mount.
On the LF motor mount there is a casting "nub" that sticks out and can wear/rub through the wiring harness. If you look behind the primary clutch on the front side, you'll be able to see the mount.
On my sled it was causing hand warmer related codes to set. It can cause different issues, depending on which wire happens to get damaged.
I cut the "nub" off with a hacksaw blade and repaired the harness.
Bill
