R
rmk addict
New member
I am currently installing "the fix" on my 09 800 RMK. I thought it had seized last year riding down the trail, I heard a noise and the sled shut off, and then was hard to turn over. T stat was reading normal temps, and I had the scratchers down.
Upon tearing down the top end, I discovered the PTO side had classic Poo smeared all over it with typical vertical scoring, and uneven feeling piston and cylinder walls, low compression....you get the idea.
Here's where it gets weird; the crankcase on PTO side was full of black oil, pretty much up to the bottom fuel injector. The MAG side was completely clean, and the MAG piston was looking okay as well.
I talked to the mechanic at my local shop, and he had not seen this problem yet.
I'm trying to think what would cause all this oil to build up, where it has been coming from, and why it hasn't been used.
I haven't split the case yet, but the outside PTO bearing case seems discolored when compared to the other three. The other three are greenish/bronze, and this one is grey, without any hue.
Like many, I am stuck with this sled for a few more years, so Im trying to make it work. Thanx in advance for the help, and lmk if I need to post more info.
Addict
Addict
