I installed some vforce reeds in my ‘20 alpha last week and got her out on the maiden voyage yesterday. Overall ran fine, but now has a weird idle quirk. When you first start it, if you don’t give it any throttle it’ll idle real low for a sec before coming up to normal idle. Also when you let off the throttle like coming to a stop, the idle will drop to about 1000rpm and sound like it’s going to die for a sec then it’ll bounce back up to 16-1700rpm and idle normal. The biggest issue is the low idle on start up. It idles low enough on initial start up that it won’t let the hand and thumb warmers power up. It’ll start flashing the hand and thumb warmer codes and they won’t ever turn on. If I immediately give it throttle on start up and get the rpm up a bit everything works fine. Anyone seen something like this after a Reed install? I made no other changes to the sled besides the reeds. Maybe I got the Iac dirty or something when removing or installing? Any ideaa?
