So my sled is an 03 1M 900 with a 162x16 track, drop brackets and a tunnel that sits really high. I find my sled really hard to carve on flat/downhill terrain.
Over the last few days I rode an 04 1M 900 with a 159x15 track, no drop brackets and a tunnel that sits super low, maybe 6-8 inches lower than mine.
This 04 that I rode was a piece of piss to throw around and carve in.
Im trying to work out what is so different about my sled and how to make mine easier to carve.
Do you think the height of the tunnel would have anything to do with this? Im thinking of removing the drop brackets and just going back to the stock location for a while. From the pics below, can I just remove the brackets and add some new idler wheels where that top bearing is located?
I also think that maybe the 16" wide track has something to do with it. I also rode a skidoo rev 141 which had a 16" wide track and found that quite tough (considering its track length) to carve as well.
Would a 1" wider track really make THAT much difference?
Im also thinking of setting the stance narrower for the front skis, do you think that would have much of an effect on tipping the sled from side to side?
Any other hints or tips? Should I loosen off the front rear suspension so I have more ski pressure?
