The water isn't necessarilly what I'm worried about, your adding a solvent and water to the air charge comming into the crankcase. ie Steam and a solvent. Ever used a steam cleaning system? amazingly effective without a solvent for removing oils and grease.Yes, his setup has an extra injector in the charge tube. It is controlled by the attitude box. You can adjust injection amount, and what boost it comes on through the box.
As for washing crank bearings down, I was concerned about that as well. Justin said that injection isn't happening untill your at boost so in theory the mixture will be vaporized from the hot air. Not that your spraying water drops into the motor. Testing and time will tell for sure.
I would be concerned that the sled would become addicted to Meth.
