Water in intake tract.
gmustangt
On the Pro Rmk, the OEM plastic airbox has a drain in the bottom , as well highs and lows to prevent water from entering the motor.
On the turbos thats gone.
I find the oem intake vents aren't 100% water tight , and water makes it way in there. Engine heat rising and melting the snow.
Running an additional Fire & Ice intake which sits horizontal and does not help water intrusion , IMO.
What are people doing to prevent water from getting through the stock intakes and in the motor?
Just pulled a intake off a sled in hood deep powder today- and sitting in the shop there was the "scary" puddles of water sitting in the intake track.... Might just make a drain with a flapper, at least I can create a lower containtment point for the H2O and "pinch" the flapper to exit any residual ..
I think most people would be surprised how much water can get in there.
Maybe they all do it and the motors are fine with it.
Your going to put a drain on the positive pressure side?
I agree. I think this is a problem as well. I've put a lot of thought into it, just haven't come up with a great solution yet
Perfect solution would be a custom formed bellmouth "snorkeled" in to the hood plenum with a prefilter on it.
Other than the bellmouth part I feel like that could be doable. Possibly a perforated 6"-8" tube section with prefilter over it might be more easily doable.
If there is that much water sitting in your intake track that's means lots made it into your motor. Doesn't that worry you? Maybe it's a non issue? All I can envision is that snow/water washing the oil film off the intake side of the piston/cylinder.
Considering it will pool at the lowest point , my concern is bottem end bearings.
There have been a multitude of smart people that have felt the premature ring wear we have been seeing in the 2011 and later CFI-2's is due to water intrusion from the stock airbox...
Going to double side tape the perimeter of all the intakes, hopefully close all the little gaps and keep 95% of it out.
I had to seal the entire mating lip from Sliber turbo carbon fiber intake to eliminate any more water from coming into the air intake - also low point drain should help.
I don't think condensation is where it is coming from- as others we have pulled off are dry as a bone.
