Do I need to remove the track and/or suspension?
Going microfiching now to see if I can get a better idea what I'm looking for.
how much water ? if its alot then its pretty much gotta be the lower case seal between the bearing and the outside (in tunnel near drivers)
what he said ^^^ look for oil running down the inside of the tunnel behind the case if you see oil then you know for sure
you will then need to
drain case oil (drain plug under sled) remove brake caliper and case cover
loosen lower gear bolt loosen tensioner take out gears and chain
loosen the track alot pull the susp. bolts and take the susp. out
run a strap over the seat and through the track to hold it up while you fix it
pull secondary loosen and remove drive shaft nuts on clutch side
then while you hold the track up off the drivers (help is nice here)
you can remove drive shaft by sliding it towards the clutch side and the out
then you can remove bad seal or bearing
i recomend changing both bearings on drive shaft unless the sled has very low miles and they feel perfect also a good time to check over everything and replace or repair as needed
good luck
let it snow
how do you figure its getting in from the top ? in the vent line ?
sincere question
