I think my voltage regulator might be possessed, what do you think??? (08 D7 163 1800 miles, no electric start)
Symptoms:
Went sledding this weekend worked great the first day. Woke up started sled and was idling low gauge flashing(first thought, TPS). Re-started sled idled fine with no instrument panel. Unplugged all three heater elements and the IP came on only above 3000 rpms. Then I realized that whenever I tapped the brake, the IP would shut off till I released brake. Messed around with heater elements and found I could use any two but not all three or else the IP would not come on. Also, the battery gauge that is normally full bars, was blinking with only one bar.
Resolution:
Ran it for 20 min(without using the brake). Re-started sled, everything worked fine. Plugged back in all three heater elements, no problems. Battery gauge thing back to full power put 60 more miles on it.
WTF???
Symptoms:
Resolution:
WTF???
