voltage regulator
I suspect my voltage regulator is going bad so i ordered a new one and it appears to be an upgraded version ......problem is my old one has one yellow wire coming out of it and 2 brown one's grounded to a bolt that holds the regulator on the machine .......the new regulator has a yellow and brown wire out of the regulator in one plug is the brown wire from the regulator a ground? not sure how to hook up the new one ...any help would be appreciated
you also can just plug your yellow wire into the yellow wire connector on the voltage regulator and just use your brown(ground) wires and ground them on the mounting bolts just like the old one was, either way it will work the same.
good luck
CK
