Its lost in the clutch, the primary actually. After the 8DN debacle (changing from 8jp to 8dn stopped wild rpm hunting) I went to work studying why this sled was so different from the Nytro clutches. I noticed our Viper came with a 2 stroke profile in the weight. That being a bump in the heel to raise take off revs (as 2 stroke have high horsepower not torque) and then a level ramp for about a third of the profile then a steeper ramp to raise rpm. And yes, why? This is a torque motor not a 2 stroke. I put the flat profile Nytro weights in (Matt from MPI suggested this, and this is what I did to our other boosted Yamahas so it wasn't anything new) and cut to desired rpm and that helped but it still seemed like something was missing. I mean this sled is a lot lighter than a Nytro and should be faster. So I came up with a bizarre test that worked.
All tests with flat profile 8FS weights cut down to 50 grams for above 10k altitude running. Weather about 25 degrees 3 inches snow on top of crust at 10k altitude. Race against 2008 Nytro with Can and a few add ons and a 2012 Nytro with 190hp Turbo
1. Stock clutches - Primary spring 35 open, 101 Shift -----------------------------------------------------Viper slightly slower than Nytro, Turbo blows it away
2. Stiffest primary spring made for this clutch (that I could find) Primary 45 open, 135 shift------------Even up with Nytro, turbo blows it away
3. Green-White-Green (aka Primary 45 open, 135 shift)with 2mm spacer -------------------------------------Viper blows away Nytro, and runs about one length slower than Turbo Nytro from stop to 50mph. Viper doesn't taper off at around 50mph and keeps pulling.
My results yours may vary.
