Vertical steering bushing
surfingeskimo
Put my vertical post on and after throwing the machine around in my garage a few times side to side noticed the bushing was Broke not sure if I should worry still seems strong but has a little play anybody else seen this happen.
Seems as though they loosen up alot. I was going to try to address this with a harder plastic one back have not got to it yet.
Check all your bolts all the way through to the frame. Some will work loose and need to be tightened.
If the bushing is broken, that is not common. If the steering is loose, make sure the bushing is in the slot. There is a rib on the bushing that goes into the slot.
