Update on the Skinz Bumper
M
MTdream
Finally had some time to do the install (too much elk hunting)...looks a LOT different when all the powdercoating is together etc.
Pardon the garage...(Motopsycho excluded, as he is a brother from another mother...:) )
Since the kit was the first one, there has been some changes, and incorporated some thoughts of people on here...
Look forward to thoughts...
It's the right idea but i wish they would have extended the bumper up to the drop brackets. If they don't do that i think it would look much better natural color so it blends in a little.
How longs that track?
I'd like that in natural myself.
I wouldn't mind a couple more inches of extension though..
track is 162 (PowerClaw)..extension would work for up to 174...the extension is tucked in quite a bit under the tunnel...so plenty to go as long as you want...
you can see the black pcoat rivets on the angled piece of the tunnel (3 rivets) that is into the extension, and the actual extension goes for another 2-3 inches..so LOADS to play with...but with 162, you really dont need that much of an extension...so it was a little overkill, but works...
looks real good woodies, I thin the left over outer tread pieces helped tie this together...looks like you got some leftover and might be able to add those in...will make it lookm really nice and finished...
thanks jeriamy not done with just about everything still lol.might have it done by mid dec.at this rate!
