Has anyone run Unifilters on a rev 800 ho I read a few threads where other have ran them and put the dpm sensor in between the filters zip tied it in between the filters , has anyone done this ?? I have some on now just experimenting but havent`t rode the sled this way and have the dpm sensor secured and fastened between the filters, I have lots of venting on my side panels, for fresh air and hot air to get out, what you think???
I know Timbersled makes a kit but pretty expensive I`m thinkin of makin my own type for me personally, does it have to have the SPI, Kickass or K&n filters and is the aluminum shield nescessary, can you put the dpm sensor around the filter like mentioned above like above one of the filters like timbersled does on there rev kit or put it somewhere between the filters ??
not sure if I beleive it or not but timbersled says the fins on the back side of the secondary fans or blows air to the filters , I don`t really beleive that..
I`m wanting to do this to free up some space in the engine compartment (Have already more room since I deleted the oil injection), and would like to loose the air boxes, if this would work I already have it figured out how I would fill the top notch or gap on the LH side panel I have an extra airbox I have cut up and used just the top part of it to still run the filter sock so it would all look stock, I have another complete outer and inner airbox set up if it need to be put back in.
any suggestions would be appreciated.
Thanks, Wildcard
Thanks, Wildcard
