two place wheel bearing check?s
Z
zr600
I have a two place aluminum trailer with the short fat tires on it i have a few ?s about the wheel bearings. How tight do you make the hub after you put new bearings in or after you repack them? It is a blizzard which is made by sled bed i believe. Where would i get bearings and stuff for this somebody on hear must have experienced this. Also is there a kit i can get to put the bigger tires on it?
Tighten the nut up and then loosen it just enough to get the cotter key through the hole in spindle, you want it to spin freely after all is said and done. Bearings should have a number on them go to a bearing house or maybe Napa will have a kit? You'll need new grease seals also. Should be able to put 12 inch wheels on it they are the taller tires.
