Could it be running out of fuel?
its doing this on a full tank of fuel fellas. This is a brand new build. I checked everything, all clamps, pistons, rings, gapped the plugs (which were burning nice and brown btw) I have stock reeds doubled up and brand new. Didnt check them but im sure they are fine since i barely ran it at all.
Neil from Boost-it confirmed with his engineer that the new programming is running normal. which i can confirm because my buddies sled was running the same updated box and had no issues.
ive had two guys tell me stator now... But that being said i still dont know why it would be detonating being rich. I really gotta see if this fuel pressure is dropping off right before i kiss the gauge.
I also have to confirm with someone to make sure my wastegate preload is set properly as its seeming tricky to get the boost down. Ive been told a stiff waste gate can cause this as well.
So its looking like Detonation from low octane caused by too much boost, or fuel starvation from stator kicking out. Or, perhaps its a bad box, not impossible by any means. Thanks again for all the info. Its gotta be one of these things. i hope
had time to read your post before you edited ......you seem angry. take it back to neil or dave, i am sure they will endorse/fix their work like always. a lot of times, your afr will read rich when in fact it is lean......take the sled back to a professional and he will fix it for you, being a newbie on a turbo setup, you can search for months what's going on, get help from a professional/reputable shop( i am sure neil or dave will help you out.A fuse which i found and fixed. I didnt realize thats why it was detonating. But it STILL doesn't run properly. Gee thanks Dave, here i thought i was just uneducated but im clearly just stupid. I guess that's why i'm asking for help because i know exactly whats going on. Here i thought this was my first turbo ever. But trying to learn is nonsense. Thank you for your help, i think i've had about enough of it. Im going to get info from people that dont talk to me like im an idiot.
