???twin pipes into stock can/silencer???
Has anyone tried modifying twin pipes to fit in the stock can. I am trying to get a summit 670 running for a beginner as cheap as possible. Would it be good?, bad?, about the same as stock set up? Will back pressure be a problem? It still has the same amount of exhaust going to the can with twins or stock pipe, right? Dont some companies sell twin pipes that fit to the stock can? I am guessing alot depends on the specific sled? What do you think???
The stock cans are really heavy. Not good. The backpressure usually drops too, so it might need an restriction. Adjusting backpressure is really dangerous because what you really do is collecting moore heat and effective compression in the cylinder, when you reach the limit of pipepressure you burn down fast... If you try it, make two entries to the first chamber in the can, one for each pipe.
