TWEAKING STOCK COMPUTERS ON 2013 PRO
Im looking to send my stock computer out to be programmed. is there a company that makes adjustments to increase performance without mounting a system on your sled?
You don't have to mount the Bully Dog unit to your sled if you don't want to. Follow the instructions to plug it in and to power up your sled (Can't have the sled running), select the tune you want and the unit programs your ECU. When it's all done, you unplug it from the sled, disconnect the power source and you're ready to ride.
To my knowledge, only SLP has tuning for the Pro-Ride chassis sleds, but that is for their stage 3 & 4 kits. Call Bikeman Performance and see if they have different levels of Bully Dog tunes for the Pro-Ride sleds like they do for they Axys chassis sleds.
Check silber turbos
Check on silber turbos , you can send in you Ecu and have them reflash it. I did mine a couple of ears ago, seem to run stronger. The only problem with that reflash is that you can only run a stock or after market can, not an aftermarket pipe. I forgot the guys name on here. Maybe he will see this an chime in.
Contact by pm member "Boston Racing" for the Silber reflash of your ECU.
