tweaked XP front end
I bent what used to be known as the flying nun on my 09. Its impossible to tell if the front suspention suport is bent or just the front end aluminum or as far back as the bulk head but left side A arm is pushed back and right side moved forrward throwing my clutch alignment out. Has anybody had any luck trying to bend back sraight with come alongs or any other way?
I have seen guys try to pull the front end straight.... It has worked at times. BUT if you go to far it will crack,,,, & break.. But if you are going to replace it anyway,, is worth a try.. If your clutches are out of wack..... ouch,, you did bend the frame. If you are handy & have a grinder, you can replace the nun at home.. Oh,, & maybe a rivit puller..
I work with a guy that owns an automobile body shop with a frame machine. I've seen him do unbelievable things.
