Due to the extremely short fueling cycle of the D.I engines it is almost impossible to inject the volume needed for turbocharging.
The only dependable method will be to either add an injector to the charge tube/airbox or just use throttle body mounted units .
D.I. by its nature is a system that strives to deliver the smallest amount of fuel needed for safe combustion and low emmisions. To do this the fuel is LATE as in its introduction to the cylinder,,ie after ALL ports have closed,
the pressures used as well as the ultra LOW volume of fuel needed to run is just NOT geared toward hi power output levels.
I fail to see the D.I. engine in its current form being a candidate for PREDICTABLE, DEPENDABLE turbocharging.
The heat increases alone would tax the bottom end even more than a turboed RT with the dreaded SDI system ,,
that too is a poor but USEABLE sytem to boost, .
For all 2 stroke turbo worshipers,, keep the mix going thru the reeds, you need to keep the base and rotating assy wet and cool it aids in avoiding deto and helps you run a cleaner fuel curve to boot..
My RT turbos are all carbed, no issue with cranks rods or realted intake side piston scoring.
RT piston scoreing on the intake side IS injector Position related.
It completly goes away when the feuling is thru the reed and the injector is removed..
pardon my spelling as I am using a laptop and have fat SAUSAGE fingers !!
Gus
