Getting a bog, or backfire on my 14 pro with silber turbo. Running pump gas, 5psi, 71g with an almond spring at 6200 feet. Sled has a 3 inch track and RKT pistons.
Sled will pull 8200 RPM, but sometimes if I let off the throttle and go to get back on it right away it will pop, and feel like it's bogging. Sled also started to do it at full throttle at random times.
I'm not really sure what to look at as the cause. Was told I shouldn't need to mix in av or 110 at this elevation at 5psi. Was told that I was probably hitting the Rev limiter, but I'm not sure because it doesn't happen constantly. Also I've never seen over 8200
TPS and TSS are checked and in spec. Power valves are clean, cannot replicate the problem on a trail, only happens in deep snow high throttle situations.
Ideas? Right now my questions are: if it was pre det, the sled should show an engine code, or flash det as its happening correct? Doesn't do that.
I feel like it's possibly a helix issue and the motor is getting loaded too hard down low with the 3" track so when I go from full throttle to off to full again the turbo doesn't have time to spool and the sled can't turn the weight (but I don't know what I'm talking about).
