G
Gobig510
So on my 2008 M8 Race Gas Turbo 13 pounds boost, my sled started acting like it has several gears. It will sometimes act like it goes completely out of gear, like someone pulled in the clutch, other times it revs up pretty high but doesn't put all the power to the ground. Sometimes it seems to stay in this lower gear, revs up pretty high, but not much track speed. The track isn't ratcheting on the drives.
I've had diamond drives go out, it is not acting like this, no shuttering or gear grinding. Gears don't seem to be sliding on one another. It is more of a smooth transition. Like a clutch is involved. Only thing I could think of it that somehow the primary clutch might be spinning on the drive shaft? Has anyone had this happen?? Thoughts? Diamond drives don't have several gears right? I can't think of how that would work. I am running the bdx lite drives, 58/62 gearing...
Thanks
Thanks
