Ok guys it's all done and i've done a test run, and well... it burned down..
damn!
Ya it sucks but i've learned so much from tinkering around i just can't give up now, I'm leaning twards detonation also.
fuel pressure was 60-ish to both rails, I did not monitor EGT's ( might put dual gauges in next time) Running 91oct
also i didn't have a "steth-a-scope" det ear muffs on so i could have had some deto.
With the turbo i have on there i'm sure it's too small now, as when we got back to the truck the bearings are gone in the CHRA
so it's got way too much backpressure, so i'm looking for a GT3076 for the next build up. after i get a minute i'll take the
top end off, and start a new thread on the tear down-autopsy.
only 4lbs.. daaamn.
well heres some pics of the final project, before i tear it down.
It's a 1:1 regulator, but i'm not putting boost to it. i should be able to control the injectors with the SIC unit and provide enough fuel without having to bump rail pressure, and to note: fuel pressure under boost was steady at 60psi.
I'll pull the air box and setup the SIC and fuel pump and see how it reacts on the bench, so after i rebuild the engine i can see how it
does... aghhhh i'm jut frazzled right now.. jager sounds good
haha
Looks like i might run it NA until i get another turbo and some EGTS... deeezanng
Fuel lines
Fuel pump
Fuel pressure reg
exhaust dump
turbo
