So after a long summer of thinking about it, researching it and doing some sleep-sledding with a turbo i'm starting the turbo RT. it's a little late but i have access to tons of cnc and metal fab equip so i can get things taken care of pretty quick. tonight is the first night on the project, i've cut up an old muffler can and used the flange fitting and the 90deg elbow to make the connection from the pipe to the turbo flange. tmmr i'm going to have the turbo flange water jetted out and then swap it into place and ditch my "mock up" one. the next few weeks will be fabbing the oil tank, charge box, boost tubes and exhaust turnout.
let me know what you guys think, not worried about the fitment or anything mechanical. fueling shouldn't be a problem with some help from the pros down the street (Turbo Performance, Thanks for offering to help! they are the bomb!) , with an O2 sensor and some egt gauges. i really enjoy tinkering with things so i'm kind of excited about this!!
here's a few pics from tonight and a few of the messy shop, sorry it's not clean but i really don't have the time to polish it up.
hour count on the fab so far. --2Hrs
Messy shop and some toys
Lathe, compressor and 3phase converter.
Tig and some junk
Made the turbo pipe tonight.
here it is in the sled, don't know if i'm keeping this turbo or not, but no big deal. i can cut the flange off and put a different one on if needed.
one more of the turbo "fitted" to the sled. need to weld on spring hoops and make the lower mounts.
So now i need to either make an oil box or see if i'm getting an aerocharger.. make the air box for the throttle bodies, boost tubes and then the exhaust dump.
i'm thinking about getting an old intercooler for a fender mount and then welding on pipe and making it into the charge box/intercooler type thing.
replacing the entire stock air box with this combo.
Tig and some junk
